02-19-2023
13:26
03:46
02-19-2023
13:26
03:46
Hi. I'm in UK. I can't add cards to Google wallet even although they on list. I can't answer calls on fitbit, just get error. Anyone else experiencing same?
Best Answer02-20-2023 03:50 - edited 07-12-2023 06:05
Hi there, @Ebrazendale. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 4.
I've seen you contacted our Support Team after posting here. Please note that your case was forwarded to our higher tier of support for further checking. Someone will be in contact with you soon as they have the resolution for the issues you're experiencing with your Versa 4.
