03-19-2023
12:00
17:18
JuanFitbit
03-19-2023
12:00
17:18
JuanFitbit
Got my Versa 4 five days ago after six or seven years of Charge 2. I mainly use Fitbit for tracking walks and the occasional run. However, despite setting up the walk tracking and stopping it on time, it doesn’t register on Strava at all?
I know the connection is live because I tracked a run on the same weekend as two long walks and only the run shows on Strava (minus GPS which is another issue).
Never had this issue with charge 2. Please help.
03-20-2023
17:18
10:35
03-20-2023
17:18
10:35
@Cifizz , A warm welcome to the Community! Thank you for reaching out.
Do you record your walks with GPS?
Keep in mind that from Fitbit to Strava only the activities with GpS will be shared.
What issue do you have with the GPS?
03-21-2023 07:11
03-21-2023 07:11
03-21-2023
11:03
10:34
03-21-2023
11:03
10:34
@Cifizz , Thank you for your reply!
The Versa 4 has a built in GPS, so that it does not need to be connected to your phone to capture your GPS data.
When starting to record your walks on your watch. Swipe until you see the activities (exercises) choose Walk and swipe up.
You should see the option to turn the GPS on/off.
Make sure it's on.
Then swipe down again, until you see the play icon. You should then wait until you see a GPS connection.
Tap on the play button to start your recording.
The straight line you se on your runs, shows, where the GPS signal got lost and where it connected again.
For better results I suggest you to have a look at this: Built-in GPS
