10-23-2022
18:17
09:25
10-23-2022
18:17
09:25
Hi there, @becki518. Welcome to the Community Forums. Thanks for the details provided in your post about the inconvenience with your Versa 4.
First of all, I'd like to mention that Fitbit Versa 4 alarms are separate from alarms you set with your voice assistant.
About the issue with your walk using GPS, please note Fitbit Versa 4 uses the formula below to calculate distance. Your stride length is determined by your height and sex. Steps x Stride Length = Distance Traveled. When you track an activity with GPS, your Fitbit calculates your distance using GPS data rather than steps. If you begin moving before you get a GPS signal, your device calculates distance using your steps until GPS connects.
To update your stride length, track a run with GPS or measure your stride length manually. For more information, see Can I change my stride length in my Fitbit account?
For more information about GPS, see: How do I use GPS on my Fitbit device?
Hope that helps.
Alarms are easiest to get to with a button tap from the clock face, then scroll up through the apps until you see alarm.
For GPS, define "way off"? A few feet to meters is expected, especially as the device trains to the GPS locations.
10-26-2022
17:25
09:25
10-26-2022
17:25
09:25
Hi there, @SunsetRunner. Thanks for adding this additional information, I'm glad you mentioned this since as you said it seems an easier way to check your alarms. Your help greatly appreciated.
Have a great day.
