Versa 4 battery not lasting enough
ANSWERED
I’m having to charge this every day. Ready to move on to a different watch. This one seems to always have some issue.
1 BEST ANSWER
Accepted Solutions
I was having a similar issue and Fitbit suggested I do a full reset. Thus far that has worked for me.
4 REPLIES 4
Hi there @Celt04, welcome back to the community.
I thank you for reporting us of the inconvenience you are facing. Please be aware that certain functions may have an effect on how long your device's battery lasts. The Always On Display is one of the features I describe. With some clock faces, you may use this option to keep the display on always.
Please take a look at this article, which lists every feature I mentioned, before deciding to purchase a different device.
Thanks @ScottMelrose, for joining this thread and sharing your suggestions with us.
Since you were able to do the full reset, I would want to offer the instructions for doing so. Additionally, I want to flag your post as the Best Answer for anyone else experiencing a similar problem.
Thanks, I’ll try that.
