Versa 4- calls keep dropping from Bluetooth on iPhone 11
Phone calls keep dropping from Bluetooth on iPhone 11
Moderator edit:  updated subject for clarity
3 REPLIES 3
Welcome to the Fitbit community, @SeniorAni!
Sad to hear that you're having issues with your Versa 4. Please make sure that your iPhone is running iOS 15 or higher to meet Fitbit's current System requirements. Also I'd suggest checking if there's an update available for your Fitbit app.
You might also want to try turning Bluetooth on your iPhone off, followed by restarting your iPhone and turning Bluetooth on again to see if this will fix your issue.
I'll keep my fingers crossed.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2
Talahthas thank you and apologies for not replying sooner. I tried your suggestion but it didn’t work. Then I realised my router/power cable was loose. So yes. I followed your instructions and I’m all set 🙏
No problem, thanks for your feedback, @SeniorAni!.
Keep moving with your Versa 4!
Stefan
