12-30-2025
07:12
08:12
12-30-2025
07:12
08:12
I keep losing access to my clockface. I reset and it's fine and then later I look and it's on the steps page or notifications and I can't get back to the clockface without resetting. I scroll all around but never get back to the clockface.
Hi there, @BobCCFL. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that the clock face on your Versa 4 is not working properly. I understand your concern, I will do my best to help you with this!
In addition to the steps you've done so far, I'd recommend trying the following:
If the above doesn't work, please restart your Fitbit device once again as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best AnswerI sync up on a regular basis to update my clock which seems to drop a few minutes after a day or two. I also restart daily in order to get the clock face back. I will try changing the clock face and see if that remains on display.
@BobCCFL Thanks for getting back to me and for the details provided, I understand.
Give it a try and let me know if the issue persists. I will be around!
@BobCCFL You're very welcome! I'm glad to hear that your issue is solved now.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
