12-01-2022
10:49
12:34
12-01-2022
10:49
12:34
I've been trying over and over fixing my distance because some odd reason it keeps changing back to 8 miles on my computer and my phone!
Best Answer12-01-2022 12:36 - edited 06-17-2023 04:49
Hello there, @Angelcowboy92. Thanks for stopping by in the Community Forums.
To better assist you, may I know if you're trying to change your goal? Of the distance you're referring to is from an activity you tracked with your Versa 4?
If you're trying to edit an activity, please see How do I add, edit, or delete Fitbit data and activities?
12-01-2022 12:48
12-01-2022 12:48
Best Answer12-02-2022 04:08 - edited 07-25-2023 03:49
@Angelcowboy92 In that case, would you mind trying one more time editing your activity on the Fitbit app and sync right away?
If the problem persists, try editing other information and see if the behavior is the same as with distance.
