04-14-2024
10:47
03:28
04-14-2024
10:47
03:28
The seconds do not count live but if I look at the watch at intervals the seconds appear to be counting.
I probably haven't explained that well!
Best Answer04-14-2024 11:24
04-14-2024 11:24
Hi @Rothera85 - it is possible with the clock face you are using, try another clock face from the Gallery to see. If you don't find one with seconds, SimpleSecretary may be a good place to start.
Best Answer04-14-2024 13:12
04-14-2024 13:12
@Rothera85 - did you also pull down on the watch face to get to Quick Settings and turn off all the icons? In case you have Always On enabled.
Best Answer04-15-2024 04:03
04-15-2024 04:03
Best Answer04-15-2024 05:28
04-15-2024 05:28
