03-07-2024
14:52
02:22
03-07-2024
14:52
02:22
Why does swim distance only register 41m when have been swimming for 31 minutes
03-08-2024 02:24 - edited 03-08-2024 02:24
Hi there, @Sandrar1918. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post, I will be glad to help you with your concern.
Your Fitbit device records your swims even if you’re a novice swimmer, meaning you can swim about 6 to 12 lengths of the pool without stopping to rest. If you’re unable to swim this distance, you may notice inconsistencies in your swim data including some lengths not counted. As your swimming ability improves, you’ll likely notice fewer inconsistencies in your data.
Inconsistencies in your swim data may be caused by any of the following:
03-10-2024 14:00
03-10-2024 14:00
These points you suggest do not apply, this swim function used to work, I have only had my watch for a couple of months, what else can I do?
