12-27-2023
08:28
08:31
12-27-2023
08:28
08:31
I went from averaging 94 AZM daily to none in the last few days. Nothing in my routine has changed.
12-27-2023 09:39
12-27-2023 09:39
Has your calorie burn gone way down? Check if you are getting heart rate readings. I don't remember if that can be turned off (accidentally) on Versa 4 in Settings, or Quick Settings.
12-27-2023 09:42
12-27-2023 09:42
12-27-2023 10:18
12-27-2023 10:18
Sorry, pardon me for seeming to have ignored that part of first post. But I would not consider accidentally tapping something in 'quick settings' that might have turned off heart rate as a change in your routine. I see hundred of times here posters accidentally doing something in quick settings without realizing it, and turning off heart rate would result in lack of AZM.
12-27-2023 12:20
12-27-2023 12:20
12-27-2023 16:53
12-27-2023 16:53
So are you blaming an update several months ago for a change in your AZM count in the last few days? Did you even check that you are getting heart rate recorded?
12-27-2023 17:17
12-27-2023 17:17
