12-10-2023
06:40
10:01
12-10-2023
06:40
10:01
My versa 4 will not work for sleep readings. It does everything else like it's supposed to but will not read the sleep.
Best Answer@BuckeyeJack Have you tried a factory reset? I would do that to see if it resolves the problem. You can restore to factory settings by pressing the side button, scroll to Settings, then choose About Your Versa 4, and tap Factory Reset.
I was up all last night, doing housework, laundry etc and my versa 4 said I slept for 6,5 hrs
Best AnswerMine did exactly the same! Brand new watch, only used for a week and from 2 days ago no sleep data are reported!
