01-18-2025
21:32
05:47
01-18-2025
21:32
05:47
I had a versa for about 6 years and had no problems my wife had a versa2 for about the same when they died I got a versa4 the biggest mistake it is half the watch as my versa the 4 will not do anything just a wast of money looking at a galaxy
Best Answer01-19-2025 20:00
01-19-2025 20:00
Hi @Clubbyboy - it is true a Versa 4 doesn't have all the features of prior watches but has a good battery life if that is important to you which a galaxy doesn't.
In case your Versa 4 has operational problems, a restart may cure it.
Best Answer01-19-2025 20:36
01-19-2025 20:36
Best Answer01-19-2025 20:46
01-19-2025 20:46
@Clubbyboy - btw. it is still under warranty if there is an actual fault. But after 8 months if there is now a specific problem have a look on the forums for an answer or post a question.
