Versa 4 is rebooting and showing red cross
my versa started a boot loop and then showed a red cross. it does not charge anymore... how can i reset it with the button? no vibration anymore after an hour booting...
1 REPLY 1
Hello there @sascha23123, welcome to the Fitbit Community.
I'm truly sorry for the inconvenience you have experience so far, please let me suggest you some troubleshooting steps.
1. Force a Sync:
  • Open the Fitbit app on your phone.
  • From the "Today" tab, tap the devices icon (in the top left corner).
  • Tap your device.
  • Tap "Sync Now."
2. Check the Gallery (If Sync Doesn't Update):
  • If you don't see an update banner after syncing, tap the devices icon again.
  • Tap your device.
  • Tap "Gallery."
  • The app should prompt you to install any missing apps and recover your device.
3. Restart Your Fitbit:
