05-16-2025 17:43
05-16-2025 17:43
I charged my Versa 4 two days ago before went to bed, then went to bed. Yesterday morning, when I woke up, the device with black screen and cannot boot up. I connected to the charger, after a while, it boot up with a red X, then went into a loop of crashing, showing the logo for a while, then black screen, then log again. I see many others post the similar issue this week. Is there a bug introduced in the recent firmware release? The device can charge and will vibrate when charger is connected. However, it fails to boot up properly. Definitely a firmware issue.
05-16-2025 18:00
05-16-2025 18:00
Definitely a firmware update issue as many of us are having the same problem!! I called and they disregarded what I said about the issue starting after the update (my battery and device worked fine prior). The rep said it was normal due to usage and offered me a coupon off of a new watch which I of course will not be buying after this terrible customer service
05-16-2025 18:00
05-16-2025 18:00
05-18-2025
16:16
11:53
FatimaFitbit
05-18-2025
16:16
11:53
FatimaFitbit
I have the same issue - new versa4 given as a birthday present. Set up worked perfectly until I downloaded latest info and crashing, won’t stay connected for more than a few secs, red X - embarrasses me and the person who gave it to me! What next? Should I log a support call too?
Moderator Edit: Formatting
05-20-2025 20:03
05-20-2025 20:03
Definitely call in case you can take advantage of warranty if there is still one active. If there isn’t a warranty, at least you can report that you’re having a problem. In my experience they were not helpful and it doesn’t seem like they will be taking responsibility for the failed firmware update and putting out a fix… I hope you have better luck!!
Best Answer05-22-2025 12:02
05-22-2025 12:02
Thanks - I’ve got all the packaging - will take it back to the shop and request a refund. Apple Watch next I think 😜
