08-02-2024
12:24
14:19
ManuFitbit
08-02-2024
12:24
14:19
ManuFitbit
It was working fine until today.
Moderator edit: clarified subject.
Best Answer08-03-2024 14:10 - edited 08-03-2024 14:12
Hi @Jasper209. Welcome to the community forums.
Thank you for providing the details about your Versa 4.
There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
For better results please try to let the device detect that you're awake or asleep by itself rather than doing it manually and make sure to keep the Fitbit app and the devices' firmware updated to the latest version available.
The Versa 4 may need some days to collect some information (particularly regarding to heart rate) and provide sleep score, sleep stages and other data. Make sure that you've also tried the restart procedure described here and check if you continue to experience the same problem.In case the problem is related to the Fitbit app, please try the following as well:
Regarding the timeline, please make sure that you are having a correct heart rate reading: What factors can affect my heart-rate reading on my Fitbit device?
