09-24-2024 23:04
09-24-2024 23:04
Over the last 2 months my calories burnt on all activities has dropped dramatically. I've gone from burning 300 calories in a hot mat pilates class to 20 calories.
Even when I go for 5km run my calories used to sit at 400+ and now I'll barely average 50 calories.
It all started when I realised my km weren't recording properly for weeks on end. I would have 10,000 steps completed by km for the day would be zero. I came in to this forum and someone suggested manually setting stride length which I did and that fixed the problem but now my calories burned is completely off??
I've also lost the pace laps when I chose running as an exercise, it just does 1 big lap but that works when I log it as a walk??
I'm really disappointed about all these glitches that I'm about to pull the pin of fitbit and invest in something else!
Best Answer09-25-2024 07:36
09-25-2024 07:36
Are you getting any heart rate readings at any time throughout the day? What about all-day calorie burn? If daily calorie burn is the same every day, I would suspect not getting any heart rate readings, so getting constant BMR calorie burn.
Also check weight didn't somehow get set very low.
Best Answer09-25-2024 16:08
09-25-2024 16:08
Ohhh this makes sense, my weight was set to 0kg!
thank you I have updated it, hopefully it works now.
