03-31-2026
12:28
20:44
ManuFitbit
03-31-2026
12:28
20:44
ManuFitbit
After the last update a few days ago my versa 4 doesn't work anymore. Tried to restart and also reset to no avail. All I get is the logo then running color stripes right to left and the 3 language buttons. Tried to sync with my phone,,,NADA help!!!!
Moderator edit: clarified subject.
Hi @Gysfit - that is unusual, first try a gentle press in the middle the watch display and see if you get into a clock change mode , if not try removing the Bluetooth entries for your watch from the phone, restart both and do a set-up and use replace.
Make sure there are no other phones/tablets or Fitbit devices turned on during the setup.
This should reestablsh a connection at least unless the watch now has a fault.
Hi @Gysfit. Welcome to the community.
Thanks for sharing those details about the issue with your Versa 4 and thank you for trying to fix it on your own.
If you are still seeing the logo on your display, please try the following:
1. Sync the device in the Fitbit app.
2. Check for available Firmware updates.
Follow the on-screen instructions: Keep the Fitbit device close to your phone during the update. When the update starts, a progress bar appears on the device and in the Fitbit app until the update is complete.
3. Charge the device:
If these steps don't work:
4. Restart the device: Keep in mind that your data won't be deleted: How do I restart my Fitbit device?
5. Changing the clock face via the Fitbit app can sometimes resolve a black screen issue:
Thanks for your help @Guy_.
