06-07-2023
04:13
04:18
06-07-2023
04:13
04:18
I have tried all the necessary steps to hard wire restart my brand new Versa 4 but nothing is working. The Fit Bit logo is not popping up after the 12 second button hold. What should I try next?
Hi there, @kelso_p. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 4 before reaching out.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?
If the above hasn't worked, may I know if your Versa 4 is vibrating while trying to perform the restart? If there's no vibration whatsoever, please try the steps provided here Why isn't my Fitbit device's battery charging?
Best AnswerThank you for responding. After I hold the button down for about 3 seconds, there is a pulse of vibration. After that, nothing happens. No logo appears or anything else.
