Versa 4 stuck on a phone icon with a line through it
I recently did the upgrade Versa 4 now little rectangle with line threw pops up & then disappears…it comes & goes?
11 REPLIES 11
@Katts1807   The update added Status Indicators and that one says your Fitbit isn't connected to your phone.  Your phone is out of range, your Fitbit app is closed, things like that.  The others are your Don Not Disturb is on, you are in Sleep Mode, or your Fitbit battery is critically low.  You can see an image here: 9to5google   You can disable this feature by swiping down on your screen and by tapping on your Settings icon.  Tap on Display and scroll down to Status indicators and toggle it off.  It is all or none.  You can't turn off individual notifications.
Laurie | Maryland
Exact same issue here. So my fitbit constantly says my phone is out of reach while I have them both right here.
i restarted the fitbit/phone, then re-installed the fitbit app. Stays the same
this started after the last update
Same. Performed update and my phone stopped working the same week. Tried to undo the update. Fitbit service said, “Sorry. Your device is damaged. We’ll give you a percentage of a new one.” This isn’t the first time this has happened. I fell for it a couple of times. Won’t buy another Fitbit/Google product.
I’m having the same issue since the most recent update that I did on Saturday. Then 2 days after the update as soon as I take my Versa 4 off the charger it shuts down and won’t turn back on until I put it back on the charger. While on the charger both the app and the watch say it’s 100% charged. I tried a factory reset. Uninstalling the watch and reinstalling it. I’m beyond frustrated. It was perfectly fine before the update.
LZeeW. Thank you for the explanation about the icons. Odd part is (and as mentioned in other posts), the "phone out of reach" icon that randomly pops up on my Versa 4 --  does so even when my iPhone and Versa 4 are within a couple of feet from one another. This is my second Versa 4 and each has worked in mysterious ways.
same here! super frustrating as I just got the watch in the fall. Really hope theres a way to fix it without turning off all system notifications
Exact same here. My phone is in my hand and my watch displays the phone icon with a line through it. Phone working with watch is hit and miss, all since the update! Originally my watch wouldn’t turn on after the update, then magically my screen reappeared but with this fault. Fitbit were going to replace but the connection options were rubbish, you have to wait until they receive the watch (upto 11 days turn around) for them to send a new one and at that it’s not a new one. They send a refurbished one! I only got this for Xmas, I don’t want someone else’s old watch! Furious!
It's their way of forcing us to get newer and/or Google products. I wish I
wouldn't have done the update. I definitely will NOT be replacing my Versa
4 with another one or a Google product.
Probably a simple glitch, reset might clear it up for good!
Deadlines were stacking up, and I needed a trustworthy site to help with my coursework. That’s when I found https://ukwritings.com/. UKwritings's a dedicated essay writing service and paper writing service for students in the UK and beyond.
Are your fitbits syncing?
Yes…mine does!
