Versa 4 stuck on weather screen
ANSWERED
versa 4 stuck on weather and will not return to main screen.
1 BEST ANSWER
Accepted Solutions
Hi there, @7244. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 4.
I agree with @Guy_, please restart your Fitbit device as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
2 REPLIES 2
Hi @7244 - that is very strange, pressing the button should solve it if the swiping of the watch face doesn't.
It may need to be restarted, try holding the button for 10 seconds, then wait for a minute while it does all sorts of things, perhaps this will clear the problem.
