04-27-2025 02:59 - edited 06-01-2025 01:02
My Fitbit Versa 4 has been behaving weirdly after updating to version 214. I used to get 5–7 days of battery backup, but after the update, the battery life is terrible (not even 12 hours). It turns off when the battery level is between 60–70%, and it won't turn back on until I connect it to the charger. Then, after about five minutes, the same issue occurs — it turns off again.
05-17-2025 13:16
05-17-2025 13:16
Same exact symptoms, along with Bluetooth issues specifically for calls. When I turn this feature off, some of those other symptoms lightened up. This battery thing, feels a little like when Apple pushed out software to fool people with iPhones thinking their iPhones were going bad so they would go and purchase new iphones, remember that?
05-20-2025
18:38
07:45
MarioSFitbit
05-20-2025
18:38
07:45
MarioSFitbit
The exact same scenario happed to my Fitbit after the software update. The battery used to stay charged for 5 days and since the update a few days ago, it doesn't last a day. I tried a factory reset and powered off. I tried turning off every permission possible. As I'm writing this, the battery percentage dropped from 79% to 69%. If Fitbit doesn't release another update to fix this, I'm done with Fitbit.
Why isn't support responding to this issue?
Moderator edit - merged messages
05-27-2025 09:11
05-27-2025 09:11
I went on chat over a week ago to complain.
They blamed my clock face being non standard.
They said I had my fitbit on all the time.
I said I'd done nothing different since I had the watch in January but since the update I had less than 2 days charge.
I was told to revert to a fitbit clock face and charge to 100% and see how it held charge.
It lasted 8 days!!!
No idea what they did, but they obviously did something to my account or app while I was on chat to them and it's back to normal now.
05-28-2025 07:29
05-28-2025 07:29
Would you be able to tell me which clock face you’re using now?? I’m using a Fitbit one but would give yours a try to see if it helps
05-28-2025 08:09
05-28-2025 08:09
the one on the left....I don't like it but there's not a lot of choice
06-01-2025 00:51
06-01-2025 00:51
Thank you for sharing. Let me try it...
06-02-2025 23:27
06-02-2025 23:27
Hi Lisa,
Could you please share the contact details for the support?
06-03-2025 18:52
06-03-2025 18:52
Same here, battery used to last 4 days or more. Now after the 214.24 update it barely lasts 2 hours! Has Fitbit support acknowledged this issue? Can someone share the contact info for support.
06-04-2025 05:33
06-04-2025 05:33
I have this problem too. Changing the “clock face” to the standard one and removing all other elements helps a little (now it doesn't reset or leave a red cross, but unfortunately it drains the battery very quickly).
06-04-2025 05:50
06-04-2025 05:50
I contacted Fitbit support via chat, but they are not even acknowledging the issue. Since it is clearly a software bug, they could easily resolve it — but they don’t seem bothered about fixing it. They are simply ignoring the request, stating that the device is not working as it should and that they can only help if it is under warranty.
I repeatedly told them that this is a common issue affecting all Versa 4 watches, but I received no positive response from the support team. I also asked for the complaint escalation matrix, but they simply said they don’t have one.
If anyone in this community has legal connections in the US, please consider pursuing legal action.
06-04-2025 06:04
06-04-2025 06:04
06-05-2025 05:51
06-05-2025 05:51
I'm so aggravated, I wouldn't buy a Pixel if it was the only smartwatch/tracker. I've been a Fitbit user for 10 years, and this is not okay!
06-05-2025 13:20
06-05-2025 13:20
In addition to the battery issues that I am having also. My Versa is stuck with both Do Not Disturb and Sleep Mode turned on. I have synced with the app and installed the latest update. I have tried resetting it both on the watch and in the app and the problem is still persisting. I have even gone as far as doing a factory reset twice. Is there anything else I should be doing to fix the issue?
06-16-2025 06:25
06-16-2025 06:25
I bought my Versa 4 to replace my two+ year old Versa 3. It was a going home present and arrived back in the US in May. Put the watch into operation ! Great and it worked great, for a while. I'm guessing the firmware made it to the watch in the last 48 hours. Yesterday I did my morning exercise hour and stopped the timer... the watch lost its mind at that point. It comes on and acts like it was never set-up. I can't get it recognized by the App. This will be my last Fitbit and the end of Fitbit premium of they do not assist with a fix. I'll give it a week.
06-16-2025 09:38
06-16-2025 09:38
I guess third time’s the charm. I did my third factory reset and it worked to get my FitBit unlocked. Finally! Now it is working well and the battery life even seems better. It was a hassle and I lost my watchface, but everything is working well now.
06-19-2025
20:59
08:43
FatimaFitbit
06-19-2025
20:59
08:43
FatimaFitbit
Ratheesht,
Since installing the firmware update I've been having the battery issues that you identified, but also a different problem. I used alarms on the device several times a day and now when the alarm goes off, I can't turn it off by tapping the checkmark on the screen, then it acts as it I have missed the alarm or snoozes it and goes off again 9 minutes later. It's driving me crazy. I'm going to try resetting it as others have done and see if that fixes the problem.
It's very annoying that Fitbit is trying to force users off Fitbit devices. I'm not ready to give up my device over this, but I'm definitely not buying another Fitbit device when the current one dies.
Moderator Edit: Word choice
06-30-2025 09:15
06-30-2025 09:15
I'm so glad I came here because I thought it was just a problem I was having. I was at 100% at 5am by 10:30 am the screen is black and when I try to turn on I get the flashing fitbit logo then a red x. With a many people having the same issue you would think fitbit would at least try to fix the problem. I've been a fitbit user since 2014 but I'm now considering going to a different brand.
07-06-2025 14:21
07-06-2025 14:21
Thank goodness it's not just mine! My Versa 4 has never had issues before, now it's just behaving strangely, draining the battery, recording a ridiculous amount of steps, not tracking my sleep or heart rate, and I am a premium subscriber!
07-06-2025 17:09
07-06-2025 17:09
I paid over $200 for this watch, which replaced my Fitbit Versa 2 that I had for 2 years. My first was a gift, but I think it cost around $150. I've also always had premium, which costs $10 a month. So Fitbit has cost me almost $1,000 since 2020. Why would I even consider buying a Pixel for another $350 if Google won't help me with the Versa 4 that I have now? If they had a better attitude about helping us with our Versa 4 software issues, maybe some of us would be willing to upgrade to the Pixel eventually (I would). Honestly, does anyone else feel confident that a new Google watch bought today will still be working in 2-3 years?
yesterday
yesterday
I think I have found the issue on my Versa 4. I was searching around different forums and found someone talking about their SpO2 app. And sure enough I see the red LED constantly flashing when it previously didn't. Looking at the app I see that the Fitbit App says the SpO2 app is not installed on the watch.
I suspect the SpO2 sensor is constantly on and taking data for no reason and draining the baterry. I had to
1. Uninstall the SpO2 app from my watch
2. Go to the heart health and SpO2 that shows app not installed
3. Press on learn more, which takes me to the SpO2 app it wants
4. Install the SpO2 app from there. And I've not seen the SpO2 sensor on constantly since then and my battery drain has been stabilized from previously
