06-14-2025
06:37
09:15
06-14-2025
06:37
09:15
Is there a way to increase the vibration alarm on my Versa 4? I am nearly deaf and the vibration on strong is not enough to wake me up.
Best Answer06-14-2025 08:46 - edited 06-14-2025 11:34
Hello @StoneyJ and welcome to the Community. The Versa 4 has a vibration setting that allows you to choose between light and strong. Swipe down on your screen to get to the Quick Settings. Tap on the gear icon in the upper right. Tap on vibration and audio, then select strong if you are set on light. Those are the only choices.
Laurie | Maryland
06-15-2025 14:20
06-15-2025 14:20
