06-03-2025 00:33
06-03-2025 00:33
I've had the phone since September 2024, goes off sync a few times but always managed to sort it,
Now the app on the phone won't find the watch after removing all information and starting again
I've tried all the troubleshooting ideas
Any help would be much appreciated
06-03-2025 20:46
06-03-2025 20:46
Hello there @Lou0, welcome to the Fitbit Community!
Thanks a lot for taking the time to share the steps you take already, let's try to get you back on track.
If you are using an Android phone, it is necessary to mention that the minimum requirements of the Fitbit app have recently changed. You need at least Android 11 or higher to properly use the app. If this is not the case, let's try the following.
06-05-2025 22:04
06-05-2025 22:04
Same issue here since two weeks...I can only sync, if i add the watch to the app again and again. Nothing else works from your troubleshooting list. Some data does not show in the app that the watch clearly measures and shows. (Sleepscore, zone minutes, etc) It is annoying to the point that i am thinking to cancel premium and change to something other than google/fitbit.
06-08-2025 21:38
06-08-2025 21:38
Hello @Csutka, welcome to the Fitbit community, all your efforts so far are truly appreciated!
I am very sorry for this inconvenience. To find a quick and effective solution, please complete this form with your information. With this information, our team will be able to provide you with the best possible assistance.
Once you have submitted the form, please let me know that you have completed it to keep you informed about the progress of your case.
