01-17-2024 13:37
01-17-2024 13:37
I am using a Versa 4, with the Fitbit app on my Samsung (Android) phone.
I set the weather units in the Fitbit app on my phone to Celsius, but it always stays in Fahrenheit on my Fitbit. All other units follow the settings in the app, however.
I have resynched many times and restated both my phone and Fitbit, but no change.
Best Answer01-17-2024 17:16
01-17-2024 17:16
Weather app doesn't obey fitbit units setting; have to go to apps - weather - settings or something like that to change the units settings for the weather app separately.
01-17-2024 19:20
01-17-2024 19:20
Hi @Pnick1908 - while @JohnnyRow is correct that it is changed from the Gallery tile in the Fitbit App, it may not be possible to change the Weather Settings though, one of the bugs in the new V4 Fitbit App will give you a blank screen if you try.
It is also possible if you see weather on your clock face that it should be changed via the clock face settings.
