11-10-2023
02:45
02:49
11-10-2023
02:45
02:49
I have an issue with my brand-new watch.
It was charging then it turned off by itself.
Now when I try to replug it, it vibrates multiples times and the charging indicator on my transportable battery doesn't light up.
When I push the button for 1sec it vibrates 1 time.
And nothing happens when i hold the button.
It doesn't look good 😞
11-10-2023 03:04
11-10-2023 03:04
Welcome to the Fitbit community, @KkOo95!
Sad to hear that you're having an issue with your Versa 4.
As there is a chance that something is preventing your device from charging, I'd suggest having a closer look here as a first approach to hopefully get things fixed:
Why isn't my Fitbit device's battery charging?
Please pay special attention to this:
How do I clean my Fitbit device?
If your Versa 4 is fully charged, please try restarting it by holding the side button for about 10 seconds until you'll see the Fitbit logo on it's display.
Finally there might be something wrong with the clock face you had selected. So please try changing it to a different one. Here's how to do that:
How do I change the clock face on my Fitbit device?
If your device is in working order after having changed it's clock face, you can switch back to the one you had used before.
I'll keep my fingers crossed.
11-15-2023 01:47
11-15-2023 01:47
none of that worked sorry. it's brand new (2 weeks) and I'm already using the official charging cable
11-15-2023 12:10 - edited 11-15-2023 12:11
Sad to hear that, @KkOo95.
If none of those has worked for you, I'd recommend contacting Fitbit support for further assistance. They'll guide you through some troubleshooting and most likely will send you a new unit if their troubleshooting won't fix things:
