02-21-2023
03:48
03:49
02-21-2023
03:48
03:49
My watch stopped syncing with the app. I unpaired my watch from the app and Uninstaller the app. I reinstalled the app and tried to sync my watch back to the app. My problem is when I connect my charger to my device to get the code, it doesn't do anything. Anyone have this happen?
Best Answer02-21-2023 03:50 - edited 07-12-2023 06:03
Hi there, @Savysmom. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 4.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
On a side note, please know if you're an Android user, you can't use MobileTrack in addition to a Fitbit device. For more information about MobileTrack, see How do I use Fitbit MobileTrack?
If you have MobileTrack linked to your Fitbit account you'll need to remove it in order to set up your Versa 4. For instructions, see How do I set up my Fitbit device? and if needed, see Why can't I set up my Fitbit device?
If you continue having syncing difficulties, see Why won't my Fitbit device sync?
