07-19-2024
05:50
07:28
07-19-2024
05:50
07:28
Versa4 will no longer pair with my android phone. I have gone through multiple trouble shoots for several days
Force quit app
Turn off Bluetooth
Unpaid all devices from phone
Restart fitbit
Deleted un-installed app & removed versa
Started over like it was new
Please help
07-19-2024 07:31
07-19-2024 07:31
Hi there, @MissKristine. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 4 is still not syncing with your phone. I understand your concern, I will do my best to help you with this!
As our last resort, I'd recommend performing a factory reset on your Versa 4. Important: Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
With the above being said, please press and hold the button for about 8 seconds until the screen turns off and vibrates. When you feel the vibration, release the button, then immediately press and hold the button again. Wait for the Fitbit logo to appear, then as soon as the logo disappears, release the button, then press and hold the button again. When you feel the vibration, release the button, then wait for the watch to complete the factory reset.
07-19-2024 07:40
07-19-2024 07:40
I did a reset through settings. It updated. Then my ovine would find versa 4 and a versa 4 for calls but would not connect with either. The versa 4 continues to say I need the app. The call one just would connect
07-19-2024 07:53
07-19-2024 07:53
@MissKristine Thanks for getting back and for the details provided.
If you're getting this message "To start download the Fitbit app", please try the following steps in the order listed:
If you can't get started with your Versa 4, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having syncing difficulties after linking your Fitbit device, please see Why won't my Fitbit device sync?
07-19-2024 09:05
07-19-2024 09:05
I have tried all of that.
My information -steps, ect. Sync. But phone notification no longer work. I'm not. Alerted when calls and texts come in
07-19-2024 09:31
07-19-2024 09:31
@MissKristine As a first approach, please keep in mind that Versa 4 Controls might be listed as “Not Connected” in the list of Bluetooth devices on your phone. When you receive a phone call, the controls automatically reconnect.
In addition to what you've tried, please try the following:
If you continue having issues, try the following troubleshooting steps:
