12-20-2023
21:36
04:07
12-20-2023
21:36
04:07
Dear All
Recently I have bought Fitbit verse 4 but after starting now it shows trying to connect
I have started several times tried on different mobile and also started by pressing for 10 sec
kindly suggest any option
Best Answer12-21-2023 03:15
12-21-2023 03:15
Welcome to the Fitbit community, @Nitish41!
Sad to hear that you're having issues with your Versa 4.
As a first approach to hopefully get things fixed, please have a closer look at this troubleshooting guide:
Why won't my Fitbit device sync?
I'll keep my fingers crossed.
Best Answer12-21-2023 04:21
12-21-2023 04:21
Hi there, @Nitish41. Welcome to the Fitbit Community Forums. It's sad to hear that your new Versa 4 is still having issues to connect properly despite all the steps you've done so far. We'll do our best to help you!
As a first approach, please follow @Talahthas' suggestion. If the issue persists, please try the following:
With the steps above, what I want you to do is to pair your Versa 4 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer12-21-2023 08:31
12-21-2023 08:31
Dear marrefitbit
I have tried the above step as said by you but facing the same issues again
Best Answer12-24-2023 11:14
12-24-2023 11:14
What phone do you have.
Have you tried stopping the app, shut off and turn on phone. In the past, these steps have has helped me
Restarting the phone will clear the Bluetooth cache, and reset hardware
On android - phone settings - apps - fitbit - Stop App
