12-29-2023
07:43
07:47
12-29-2023
07:43
07:47
I am not receiving any notifications on my fitbit and when I go to my Bluetooth settings and try to connect to my versa 4 it says an app is needed.
12-29-2023 07:51
12-29-2023 07:51
Hi there, @Kaitlinsmith. Welcome to the Fitbit Community Forums. It's sad to hear that your Versa 4 is not is receiving notifications. I'll be glad to help you with this.
As a first approach, I'd recommend checking whether your Versa 4 is in sleep mode. When sleep mode is on:
If the above doesn't describe your issue, please see Troubleshooting quick tips for iPhones and/or Why are notifications delayed or missing? depending on your phone.
12-29-2023 07:53
12-29-2023 07:53
None of that works. My phone is telling me I need an app to connect to my fitbit. It's connected for steps. But what app do I need? This makes no sense.
12-29-2023 08:08
12-29-2023 08:08
Hi there, @Kaitlinsmith. Thanks for getting back and the details shared in your post above.
As per the message you're getting, it seems like your Versa 4 is not properly paired. With that being said, please try the steps below in the order listed:
With the steps above, what I want you to do is to pair the Versa 4 first to your phone's Bluetooth settings before any other Bluetooth device is connected to the phone.
