Versa 4 won't connect to my phone's Bluetooth
I have this versa 4 for almost a year and it was connected to my phone. Past 2 weeks I am not able to connect it..
- removed app, reinstalled app
- restarted phone
- restarted app
- bluetooth disconnected and reconnected
- tried connecting on another phone still no luck.
PLEASE HELP
5 REPLIES 5
Hi there, @Arnie_T. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 4 is still stuck on the Fitbit logo. I understand your concern, I will do my best to help you with this!
In addition to the steps you've done so far, please try the following steps in the order listed:
  • Unpair your Fitbit device from your phone's Bluetooth and Fitbit app.
  • Unpair other Bluetooth devices that you may also have paired to your phone's Bluetooth settings.
  • Force quit the Fitbit app.
  • Turn off other Bluetooth connections when not in use. This can help to prevent connectivity issues or Bluetooth interference.
  • Turn on the Bluetooth on your phone.
  • Plug it into the charging cable and open the Fitbit app.
  • Set up your Fitbit device.
  • If there is no connection, restart your Fitbit device.
  • Once your Fitbit device is paired and syncing, please proceed to set up your other Bluetooth devices to your phone again.
With the steps above, what I want you to do is to pair your Versa 4 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Hi,
Thank you for providing additional steps. I tried doing it multiple times but versa 4 is still not connecting.
I tried to connect it on another device as well and that did not work either.
I have the exact same issue which also started around the same time as you. Have you been able to get around it yet?
To add: I did all the steps recommended by @MarreFitbit above but the problem still remains. Please help.
Did a factory reset on the Versa 4 and finally the error is gone. But so is all of my history from the device.
