Hi @Boon9 which Versa do you have? You posted in the Other Versa forum area, label is Versa 3 and you mentioned a Versa 4. On the newer devices, the alarm is set directly on the device, not the app.
12-14-2022
04:42
06:43
12-14-2022
04:42
06:43
Hello @Boon9 and welcome to the Community. You press the button once to get to the Apps menu on the Versa 4. They are in alphabetical order, unless you have used any of them. Then they are divided into Recent and All Apps. If you have been navigating by swiping only, please press the button. If you still don't see it, please do the following: tap on your profile avatar on the Fitbit app > Versa 4 > the Gallery tile > slide the toggle to Apps > look for Alarms > install. Alarms should be preinstalled by default.
I moved your post to the Versa 4, since you wrote that you have a new Versa 4.
Laurie | Maryland
