08-20-2023
11:35
04:38
08-20-2023
11:35
04:38
Why doesn’t my versa4stay connected to Bluetooth?
08-21-2023 04:42
08-21-2023 04:42
Hi there, @Weakleyla. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 4.
In addition to the steps recommended by @Talahthas, I'd add the following:
With the steps above, what I want you to do is to pair your Versa 4 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Nevertheless, I've seen you contacted our Support Team after posting here but your chat got disconnected. If none of the steps provided above work, please feel free to contact our team back for further assistance.
08-21-2023 03:19
08-21-2023 03:19
Welcome to the Fitbit community, @Weakleyla!
Sad to hear that you're having issues with your Versa 4.
To hopefully get things fixed please make sure that your phone is running an OS that meets Fitbit's current system requirements as mentioned here:
If so I'd suggest turning Bluetooth off and on again on your phone. You could also try if restarting your Versa 4 will have a positive impact on Bluetooth connectivity. To do so first sync your device to not lose any data it has tracked so far. Then keep Versa 4's button pressed for around 10 seconds until you 'll see the Fitbit logo on it's display.
If you're still out of luck, I'd recommend setting up your Versa 4 for on-wrist calls from scratch following the instructions provided here:
How do I take on-wrist phone calls with my Fitbit smartwatch?
I'll keep my fingers crossed.
08-21-2023 04:42
08-21-2023 04:42
