01-13-2026 08:32
01-13-2026 08:32
I have a new versa 4. It will not stay on nor will it “wake up”. The battery is 100% charged. I have done resets and a factory reset. No change.
01-13-2026 15:42 - edited 01-13-2026 15:47
Hello there @Catmil3, welcome to the Fitbit Community.
Thanks a lot for taking the time to share this with us, I'll be glad to help you out!
I was wondering, were you able to get the device set up at all? If so, could you check the app to see if there’s a pending update?
Either way, let’s try restarting the device by following these instructions:
This is another way to force a factory reset on your device. Once you perform this process, you can try to set up the device again.
Best Answer01-14-2026 07:21
01-14-2026 07:21
Best Answer01-14-2026 08:45
01-14-2026 08:45
Hi @Catmil3! Thank you for your reply.
Thank you for all the steps you tried.
Please clean the charging pins on your Versa 4 and the charging cable by following the instructions in the link below: How do I clean my Fitbit device?
Additionally, after cleaning the charging contacts try again a restart by pressing the button for at least 12 seconds, once the contacts are clean and the reset is done, please connect it to the charging cable on a computer and leave it for a few minutes to check if it charges and reacts.
