03-30-2025
20:15
04:13
03-30-2025
20:15
04:13
I have a somewhat new phone, OnePlus 12. I initially paired it just fine, but recently it won't sync data so tried troubleshooting the issue. I've done everything, pretty much reinstalled the app to restart phone and versa 4. Nothing seems work. It just won't pair at all.
Best Answer03-30-2025 21:45
03-30-2025 21:45
Hi @xeoneex - if you changed phone make sure there is no old phone still working.
Did you try removing the watch Bluetooth entries from the phone and restart both watch and phone and in the Fitbit App, tap the device/battery icon and Add more devices and replace?
See also Why won't my Fitbit device sync?
03-31-2025 04:18
03-31-2025 04:18
Hi there, @xeoneex. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 4 is not syncing to your new phone. I understand your concern, we will do my best to help you with this!
I was wondering the same thing as @Guy_. I'd suggest making sure that your Versa 4 is no longer connected to your old mobile device as this might be preventing your Fitbit device to properly sync and connect to your new phone.
With that being said, please follow the steps below in the order listed:
With the steps above, what I want you to do is to pair your Versa 4 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
If the issue persists, please follow the troubleshooting steps provided in the help article that @Guy_ has shared with you.
Best Answer03-31-2025 05:37
03-31-2025 05:37
It won't connect to the fitbit app. Thats the problem right now. I removed it from the fitbit app since it was't syncing now it won't pair at all with the phone.
Best Answer03-31-2025 05:38
03-31-2025 05:38
I'll try this to see it if works
Best Answer03-31-2025 05:39
03-31-2025 05:39
And the old phone is gone and was already factory reset
Best Answer03-31-2025 05:52
03-31-2025 05:52
Got as far as pairing and it just sits there nothing else is happening. Connecting your Versa 4 to the Fitbit app... watch screen goes from pairing to black screen and nothing happens.
Best Answer03-31-2025 06:01
03-31-2025 06:01
Ok it finally paired everything is working. I dont know why it took so long to pair. Took several minutes
03-31-2025 06:50
03-31-2025 06:50
@xeoneex I'm glad to hear you managed to connect your Versa 4 to your new phone.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
