05-22-2023
11:16
11:18
05-22-2023
11:16
11:18
My versa 4 will not sync. I shut down my versa, uninstalled and reinstalled my Fitbit app and nothing is working. Are there any sync issues with Android?
Best Answer05-22-2023 11:20
05-22-2023 11:20
Hi there, @bgood247. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Versa 4 prior to posting here.
In addition to the steps you've done, please try the following in the order listed:
With the steps above, what I want you to do is to pair your Versa 4 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
05-22-2023 11:20
14:18
05:27
05-22-2023
14:18
05:27
My versa will not shutdown. When I scan for the device it sees the Versa but I get a message, "An app is needed to use this device."
Update: I did a hard reboot and it appears to have fixed the problem.
Best Answer05-23-2023 05:29 - edited 05-28-2023 04:46
@bgood247 I'm glad to hear your issue is solved now.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
