11-26-2022
07:21
03:55
11-26-2022
07:21
03:55
The Versa 4 shows calories burned however the amount is roughly 1/2 of two online calculators and that of the Echelon fitness bike.
Best Answer11-26-2022 09:17
11-26-2022 09:17
So many potential issues with the little information you gave:
Best Answer11-26-2022 09:32 - edited 11-26-2022 09:38
@JohnnyRow Echelon bikes use a power-meter-like method to estimate calories (a proprietary algorithm which doesn't need details like weight or age). They don't have a built-in power meter though but estimate power by (now I'm simplifying) cadence x resistance. It comes close enough to real power meters. Calories are based on wattage (watts x 3.6 x time) and don't include BMR (as it's the case with smart trainers and outdoor power meters). This may be a reason why the bike shows lower energy expenditure (the algorithm only simulates the power meter, similar to what Zwift does when using a non-smart turbo trainer and that doesn't include BMR)
edit: just got to me that the bike shows a higher number of calories. In that case, I also suggest seeing whether HR readings are accurate. We are talking about Versa 4 so I would first start looking at this area.
11-26-2022 14:46
11-26-2022 14:46
Best Answer11-30-2022 07:50
11-30-2022 07:50
Thanks for your reply.
1. V4 calories burned: I use the V4 exercise (Spinning) app to log/record the activity. The calories calculated from this app tend to be roughly 1/2 that of the on line calculators...
2. Online calculators: I'll often compare the FitBit Spinning app calculated calories burned against the following online calorie calculators. Both calorie calculators listed allow the user to enter user weight, intensity of work out (to some extent), and duration of work out.
https://caloriesburnedhq.com/calories-burned-spinning/
I understand that calories burned is an estimated figure and expect variation in the calculations. However I was quite surprised to see such a wide variation int he calculated numbers, leaving me wondering what calculation best reflects reality.
Thanks!
Best Answer11-30-2022 08:17
11-30-2022 08:17
@Precchio you said you have V4. Have you verified your HR? Versa 4 and Sense 2 are known for bad HR quality and that may affect the calories. Online calculators are just that, calculators that are based on certain assumptions and statistical data. Probably, none of them is correct. I explained a little more by replying in this thread and the user there has actually an opposite problem, his Fitbit reports more calories. For spinning, it's best to rely on power meters which are closest to reality (although they don't include BMR but only report work in watts that you've done). Everything else, including HR or calculators, is just a guestimate. May work for one person but won't for another.
