08-20-2024 07:38
08-20-2024 07:38
I've looked for a setting once I open walk, but there is no option to try and connect to gps like you can a run.
Best Answer08-21-2024 04:56
08-21-2024 04:56
I see the option on mine. Other Exercises>Walk
Then scroll down.
Best Answer08-21-2024 13:44
08-21-2024 13:44
@Meadli I apologize if I misread what you wrote. It sounds like when you open the Exercise app and choose Walk, you don't see the GPS connecting icon with the twirly arrow. Please swipe up on the tiny "^" at the bottom of the screen to access all the Walk settings. You should see the GPS option just below the Show stats section. Make sure it's toggled on. If I remember correctly, it was off by default when I got my Sense 2 (same firmware). Scratched my head a lot over that Fitbit decision.
Laurie | Maryland
Best Answer08-21-2024 14:29
08-21-2024 14:29
08-21-2024 14:48
08-21-2024 14:48
@Meadli If you were starting your walk from the tile that has the three icons, those are quick start shortcuts. You can’t change settings from there. They are tap and go. Glad you got it fixed.
Laurie | Maryland
