Versa 4 won't turn on
My watch shut down by itself and doesn't work properly
2 REPLIES 2
Hi there, @Hemanshu. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that your Versa 4 has shut down by itself. I understand your concern, I will do my best to help you with this!
If you haven't done so yet, please try the steps below:
  1. From the Today tab in the Fitbit app, tap the devices icon at the top-left corner.
  2. Tap your Fitbit device image.
  3. Near the bottom of the page, tap Sync Now.
If the above doesn't work, please restart your Fitbit device as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hi,
Thank you for your reply and support.
I have tried all the options that you sent me, but the problem is still the same. Kindly reply to me with a better solution for the issue.
