07-17-2024
08:49
03:57
07-17-2024
08:49
03:57
I just got my fitbit versa 4 yesterday. When I set it up it, it looks like it loaded everything correctly, but the 'update tracker' button is still showing. When I push that button, it tries loading the update but takes a long time and then seems to time out. Also, the phone will not sync.
I have tried:
1. Deleting and reinstalling the app
2. Factory resetting the tracker
3. Powering off my phone and restarting
Is this a tracker issue or something else? Should I try exchanging the tracker?
I have an iphone 11 if that makes a difference. I appreciate any help!
Best AnswerHi @bemark is your phone running the minimum required iOS 15? click to learn more.
Trouble syncing? See if anything in this article helps you
Best AnswerThanks for the response.
My phone is on IOS version 7.5.1.
I have tried everything listed in that article.
