12-26-2023
05:27
06:44
12-26-2023
05:27
06:44
Tried to setup my new versa 4 today but it just sticks when attempting to update the tracker firmware, my phone and the tracker are paired, as soon as i click update the tracker just comes up with trying to connect and doesnt update. I have tried using another phone, uninstalling app, reboot phone, reboot tracker, nothing works??
12-26-2023 17:46
12-26-2023 17:46
Mine is doin the same. Please let me know if you get it figured out.
12-26-2023 21:01
12-26-2023 21:01
Hi @Dpuglas93 @Sheenalynn - the fault in the new V4 Fitbit App won't allow updating firmware.
12-27-2023 00:46
12-27-2023 00:46
Im contacting support so ill let you know.
Best Answer12-27-2023 13:47 - edited 12-27-2023 14:30
I tried different app versions, the result is same...
4.04.2.11 / 4.06.7 / 3.89 / 3.75 / 3.29
Best Answer12-27-2023 19:16
12-28-2023 01:51
12-28-2023 01:51
Have you tried it yourself? All the symptomps are same as others. I don't think it's app version related, because the result is same. After updating for 1 second connection is lost. Maybe it's Versa 4 new software versions fault?
Best Answer12-28-2023 02:08
12-28-2023 02:18 - edited 12-28-2023 02:29
Same as me , trying to update tracker software connects then discconects and remains trying to connect , i have 2 versa 4's both are doing the same .
Best Answer12-28-2023 02:21
12-28-2023 02:21
Could other people try updating via older version of Fitbit app not from PlayStore? Would be intersting is this is the case.
Best Answer12-28-2023 02:40
12-28-2023 02:40
Trying with older versions of the app and still no joy. im lost now with what to do
Best Answer12-28-2023 02:50 - edited 12-28-2023 02:54
@markeagles4 , @aubaR7 - using the version 3 app try removing both the Bluetooth entries from the phone and turn off the phone Bluetooth
Then Logout of the Fitbit App and swipe off the active window and in Android clear the storage cache and force stop it and then restart the phone.
Make sure there are no other devices running the Fitbit App switched on or other watches on.
Restart the watch by holding the button for 10 seconds till it vibrates and the logo appears and wait for it to start.
Turn on Bluetooth and Login to the app and run Set up a Device and replace and try again.
If that doesn't work, remove watch and any other devices attached to your account and repeat the process.
Best Answer12-28-2023 03:21
12-28-2023 03:21
Done this many times. Step by step. Also, I cleared cache and data from Fitbit app and restarted phone before every new pairing. Still no positive result...
Best Answer12-28-2023 03:35
12-28-2023 03:35
Still no joy .
Best Answer12-28-2023 13:40
12-28-2023 13:40
Same problem as all above and same thing on screen as markeagles4. Got this for Christmas, and had problems starting the next day. Am ready to box it up and send it back. Guess I'll have to buy an Apple. 😞 I think it has to do with the move to google. I am very not happy.
12-28-2023 20:45
12-29-2023 00:56 - edited 12-29-2023 01:49
My watch is on version 61.3001.153.66
Best Answer12-29-2023 02:04
12-29-2023 02:11
12-29-2023 02:11
Yes, the watch is brand new. But it doesn't update with V3 Fitbit app. I cannot use it without update, it forces me to do so.
I actually managed to connect it once the day I bought it and tried to test it before putting it under Christmas tree. It took me 2 hours or so but I managed it to connect after many reconnections. But now after Christmas it doesn't connect no matter what I try.
Best Answer12-29-2023 02:24
