10-17-2023
09:08
08:55
EstuardoFitbit
10-17-2023
09:08
08:55
EstuardoFitbit
I've just recently changed from a luxe to a versa 4 and my zone minutes are super low all of a sudden. Is this a problem with the versa 4?
Moderator Edit: Clarified Subject
10-17-2023 16:48
10-17-2023 16:48
I have had the same problem.
10-20-2023 17:23
10-20-2023 17:23
Not sure if Fitbit monitors the community and can help with this problem?
10-24-2023 08:37 - edited 10-24-2023 08:52
Hi there @Lanajd @AngelaMay. It is nice to see you around guys.
Thanks for letting me know about this inconvenience with the zone minutes.
Given that your Fitbit device will track your zone minutes based on your HR, I recommend that you restart your device. Cleaning the back of your device with fresh water will also significantly enhance the way your device tracks your HR.
More information on zone minutes can be found here.: How do I earn Active Zone Minutes?
Best Answer10-24-2023 08:46
10-24-2023 08:46
Best Answer10-24-2023 08:54 - edited 10-24-2023 08:56
@AngelaMay Let me assure you that a regular restart will not result in data loss.
Best Answer10-24-2023 08:55
10-24-2023 08:55
Best Answer10-24-2023 10:24
10-24-2023 10:24
@AngelaMay Since you have a Versa 4, is as easy as pressing and holding the left button for about 10 seconds.
Best Answer10-24-2023 10:34
10-24-2023 10:34
