Versa4 only blood pressure in red on front screen no green or purple
On the front on the watch only the red, blood pressure is on no green or purple information
2 REPLIES 2
Hello @Otisotisdog2 and welcome to the Community.  I apologize if I'm misreading your post.  It sounds like you are describing the Paths Standard clock face.  This is the default clock face that is on the Versa 4.  The red line is your heart rate, not blood pressure.  It will change with your heart rate in real time.  No Fitbit measures blood pressure.  The green line is active zone minutes.  That line doesn't change until you've earned active zone minutes.  The purple is your sleep score.  I can put this clock face on my Sense 2 and noticed that it can take an hour or more for the sleep score to appear on the clock face.
I hope this helps.
Laurie | Maryland
Thank you so much for the info.
Sent from my iPhone
