What is the best option for me Versa 3 or Versa 4
ANSWERED
Want to upgrade from versa lite? Should I buy a versa 3 or should I future proof my versa and go for the new versa 4? is there scope that versa 4 updates will come on stream making it a better option than it is right now? Opinions? Thanks
1 BEST ANSWER
Accepted Solutions
Hi @SunsetRunner  - unless there is something specific you want, go for the Versa 2, it is compatible with your existing watch and you should be able use any clocks or apps you have on it currently ,but check first.
The Versa 3 has more features than a Versa 4.
If you want reliable heart rate, charging and vibration go for the Versa 2.
2 REPLIES 2
Thank you for that info
