02-22-2024
04:40
16:02
ManuFitbit
02-22-2024
04:40
16:02
ManuFitbit
When receiving a wrist call on versa 4 says connection error. Hiw to fix?
Moderator edit: clarified subject.
02-22-2024 15:49 - edited 02-22-2024 15:49
Hi @DebbieM1960. Welcome to the community forums.
Thank you for sharing the inquiry regarding the Versa 4.
Please, make sure that your Versa 4 is listed on your Bluetooth options as Versa 4 calls. You should have both options: Versa 4 and Versa 4 calls.
Also, go to the Fitbit app, tap on the upper left corner on the device and phone icon, and look for the Versa 4 option: select on wrist calls and set it up.
If you continue having issues, try the following troubleshooting steps:
