09-04-2022
18:24
07:58
09-04-2022
18:24
07:58
Will the Versa 4 be compatible with bands for previous Versa models?
Best Answer09-04-2022 18:37
09-04-2022 18:37
Yes, you will be able to use the Versa 3 bands with it.
09-04-2022 18:37
09-04-2022 18:37
09-05-2022 04:29
09-05-2022 04:29
@Karissa0104 Where did you see that? Have a link? Previously, no two trackers were able to share bands.
Best Answer09-05-2022 05:35
09-05-2022 05:35
The Fitbit online store for bands says that are compatible for Versa 3 and Versa 4
Best Answer09-05-2022 05:43
09-05-2022 05:43
@MarkMM Not here to nitpick, but the following devices share bands:
Laurie | Maryland
09-05-2022 05:47 - edited 09-05-2022 05:48
You even forget Versa Lite that shares bands with Versa and Versa 2 (and now we have 3 devices!)
In addiiton bands of Inspire and Inspire 2 can even be attached to Ace 2 and Ace 3 (in case a 12-13 years old boy/girl finds the original ones a bit too childish).
Well, in this case even Alta, Alta HR and Ace shares bands
Oh well, I forgot Sense and Versa 3 (so now we have Versa 3, Versa 4, Sense, Sense 2)
09-05-2022 05:59
09-05-2022 05:59
@Dopovo Well spotted. Then again, if I put them all on one list, it would appear nitpicky, despite my claim to the contrary. 😉
Laurie | Maryland
09-05-2022 06:58
09-05-2022 06:58
Thanks for the correction. Apparently I'm WAY behind. 🤣
09-05-2022 11:21
09-05-2022 11:21
Go on the website to where you can purchase the bands, when you look at the categories the one shows sense, sense 2, versa 3 & versa 4.
Also yes the Versa 1 & 2 used the same bands, I had had them both and was able to use the same bands.
