05-15-2018 17:56
05-15-2018 17:56
Has anyone else noticed all-day sync sucking your phone's battery (I know it will deplete the tracker's battery faster)?
05-15-2018 18:01
05-15-2018 18:01
From what I’ve been told, yes, all day sync does affect the life of your battery. So, I always have it off and just manually sync. But I’ve also been told that syncing also causes battery drain too.
05-15-2018 20:02
05-15-2018 20:02
Hi! Where do I change it to manually sync?
05-15-2018 20:08
05-15-2018 20:08
oh by syncing manually, i have to turn on my Bluetooth and location (instead of leaving it on) and open my Fitbit app, I pull down the screen to sync or have it sync automatically then when I open the Fitbit app. I do that every time I want to sync my Versa.
05-15-2018 20:13
05-15-2018 20:13
Where do you turn the automatically sync option off?
05-15-2018 20:18
05-15-2018 20:18
The all day sync is kinda like an automatic sync so you can just turn that off and see if that saves a bit more battery. But leaving your Bluetooth on also drains battery but if you turn that off, you won’t receive any notifications or alarms.
05-15-2018 20:22
05-15-2018 20:22
Thank you! I turned off the all day sync. I have to keep my Bluetooth on because I have other devices. But hopefully that helps!
05-15-2018 20:26
05-15-2018 20:26
You’re welcome and Good luck!
05-15-2018 22:16
05-15-2018 22:16
Did you paired it with the phone?
If you did and stiil don't see it, unpair and pair it again. Make sure you have the latest version of the Fitbit app installed on your phone.
