Not getting notifications on versa from my samsung galaxy M30 mobile phone
I am not getting any notifications on my versa from my Samsung galaxy M30 mobile phone. Phone can be synced for other monitoring like walk steps etc. but could not get notifications for calls, sms, etc.
It was working very fine with my earlier phone.
What to do for getting these notifications ?
Thanks in advance.
6 REPLIES 6
Is the device you are trying to sync to a supported device? If not, notifications usually do not work.
You can find a list of compatible devices here and here.
Have you checked permissions, settings,, and the on the ionic notifications are enabled?
Have checked the help guides?
How do I get notifications from my phone on my Fitbit device?
Receive call, text message, calendar, and other notifications on your Fitbit watch or tracker if you have a compatible phone.
My Fitbit device isn't receiving notifications from my phone
Try these troubleshooting steps if you're not receiving notifications
Hello Mohril.
Did you end up able to receive notifications on your M30?
I am considering buying the same phone but only if notifications work with it.
Thanks,
Luke.
My Galaxy M30S is not working. Its not in the supported device list yet.
Make sure your notification acces is set up in the fitbit app
And leave your app run in the background
Make sure notifications show on the phone while the phone is locked.
When installing the app, where you asked to approve access to notifications.
