09-13-2019
06:35
11:58
LizzyFitbit
09-13-2019
06:35
11:58
LizzyFitbit
Everything is connected Im getting text and phone calls and my steps sync with the app.
The Spotify won't connect Ive did a reset
I just dont know what more to do
Also I dont have the 7 stars when you swipe up and it wont let me add it
Help me please and thank you
Moderator edit: format and updated subject for clarity
09-13-2019 12:52
09-13-2019 12:52
Hi @TamiiCoco and welcome to the forums. Which phone do you have? As for the missing “7 stats,” if you are referring to the stats that appear on the Versa when you swipe up, you should see a Settings button. Tap that to set up which stats should show up on your screen.
p.s. Please do not post using ALL CAPS. It’s not good netiquette and is more difficult to read.
09-15-2019 14:52
09-15-2019 14:52
Hello,
I'm having the same problem. Everything else is synced / connected except for the Spotify app and I can't seem to get it to work. Does anyone have a solution for this? I've already googled and nothing is helping.
09-15-2019 17:09
09-15-2019 17:09
I'm also having issues with Spotify connectivity.
Phone's Bluetooth is on and paired with the Versa 2.
Spotify app is added and logged in under the Versa 2 mobile app settings.
Spotify account has premium on it.
Under all conditions I seem to get:
"Make sure your phone's Bluetooth is on, then sync your device using the Fitbit mobile app."
I've also tried syncing headphones to both the phone and to the Versa 2 but there seems to be no change in result.
09-15-2019 22:49
09-15-2019 22:49
I have this issue as well. Versa 2 is connected but the Spotify app can't find my device.
I personally am using the Google Pixel 2.
09-15-2019 23:10
09-15-2019 23:10
Also having the same issues with spotify.
All other apps work but spotify whenever i try connect spotify i get the message below.
Currently using mate 20 pro.
09-16-2019 09:26
09-16-2019 09:26
Same here. All is syncing correctly except the Spotify app, which shows the "Make sure your phone's Bluetooth is on (...)" message on the watch.
Bluetooth is on and the watch syncs, I have Spotify account added in the Spotify options of the Fitbit app and I'm a premium user. Can't guess why it isn't working, this is really annoying...
09-16-2019 09:30
09-16-2019 09:30
Forgot to say that I'm using a Oneplus 6T and Android 9 Pie.
I also turned off battery optimisation for the Fitbit app and tried restarting the watch.
09-17-2019 06:33
09-17-2019 06:33
Strangely enough, it got solved after restarting the phone. I'd advise you to try that.
09-17-2019 08:05
09-17-2019 08:05
Restarting my phone worked for me. Pixel 3
09-17-2019 08:55
09-17-2019 08:55
On another note. Any issues with receiving texts? I heard that this was a problem. I want to get a Versa, but want to know what other users think.
09-17-2019 10:33
09-17-2019 10:33
Same issue for me, using an Honor 10.
Spotify app reinstalled on watch, Fitbit app reinstalled and syncing fine via Bluetooth, Spotify Premium account logged in via the app, all permissions granted.
09-17-2019 13:47
09-17-2019 13:47
Same issue here. Pixel 2, Spotify premium, all permissions granted and reset the phone
09-17-2019 22:06
09-17-2019 22:06
After i reset the phone spotify starting working
Eneko89 Thanks
09-19-2019 12:40
09-19-2019 12:40
This worked for me:
Go to your Fitbit app.
Then Account > Versa 2 (or other device) > Apps > My Apps.
Click Spotify Settings and log in.
09-20-2019 09:28
09-20-2019 09:28
10-15-2019 20:21
10-15-2019 20:21
Try turning your phone off. Then back on. It worked for me.
10-26-2019 10:09 - edited 10-30-2019 19:29
Restartings worked for me, Pixel 3a
Thanks!
10-30-2019 19:26
10-30-2019 19:26
Initially restarting my phone worked and I was able to use controls. But it has disconnected and I can't establish a connection again. I have tried uninstalling and reinstalling the Spotify Fitbit app, ensured that I was logged in to Spotify In the settings, phone connected to wifi. And Fitbit connected by Bluetooth to phone. When it didn't work I restarted my phone again and I had to manually connect by Bluetooth again via the settings on my Versa. Still won't work and prompts either to connect by Bluetooth and sync or to ensure phone is connected to the internet when both of these have been done. Feeling very frustrated.
Using pixel 3a.
11-29-2019 15:32
11-29-2019 15:32
Same here. Have set everything up but it will not connect and cannot get headphones to work. I bought 2 of the versa 2. One for me and one for the wife. Will be returning both
