11-01-2019 00:31
11-01-2019 00:31
I bought a Versa 2 a few days ago. Right from the start, it kept dropping the bluetooth connection, occasionally connecting after many attempts over 20-30 minutes and then dropping within anything from a few seconds to a few minutes.
I tried all the following:
- Turning on 'All Day Sync', 'Always Connected' and 'Keep-Alive Widget'
- Restarting the phone (Samsung Galaxy J5), the watch and the Bluetooth
- Unpairing all paired deviced from the phone
- Reinstalling the Fitbit app
- Trying to use the Fitbit app on a Microsoft Surface laptop instead
- Holding the phone in the hand with the Fitbit on (i.e. very close)
- In the city and in the countryside, plus in different kinds of buildings
- Getting another new Versa 2 (all the same problems!!!)
As a result of these issues, the Alexa and Spotify apps are unusable, and the device rarely stays connected long enough to download a new app onto the watch, or to take advantage of things like water logging from the watch, comparing calories in with calories out etc.
The kinds of messages I am getting are "No Device Found" or "Make sure your phone's bluetooth is on..." or "Error connecting with Versa 2. Please make sure your Fitbit is nearby...".
Any ideas? I am going to write a product review next week and I am hoping to have something better to report!
Thanks in advance.
11-01-2019 02:23
11-01-2019 02:23
I have the same problem. Even though my Bluetooth shows as being connected to the watch it won't sync. Then I will remove and reset watch and it gave me option to connect to Wi-Fi so I did and it finally synced. Then after 11 hrs it disconnected again and won't re engage.
11-04-2019 23:26
11-04-2019 23:26
Hello Kimmy58.
I sent an email to Fitbit technical support and they said my phone was not on the list of compatible devices here:
https://help.fitbit.com/articles/en_US/Help_article/2315
I tried an iPhone instead for 24 hours and it seemed to work fine with that. So that was the problem in my case. I do recommend contacting Fitbit here:
https://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
I hope you get an answer soon!
12-06-2019 10:24
12-06-2019 10:24
I have spotify premium. When I go into my watch to spotify it says not connected. I look at the fitbit app, spotify settings and see it says Spotify free, log out. So I log out again and log back into my premium account and then I can access my libraries and such on my watch. This happens multiple times a day. WHY won't it stay connected to my premium account? I've uninstalled and reinstalled Spotify on my phone, set to run in background. I've uninstalled and reinstalled fitbit app. I don't get it.
12-16-2019 14:55
12-16-2019 14:55
How is this the "Best Answer" when it won't engage again?
This issue was never root caused and corrected in any of the other messages.
I just got my versa 2 and have the same problem. This is BS.
12-18-2019 15:09
12-18-2019 15:09
Recieved my Versa 2 a couple days ago and having the identical problem. Did everything possible, uninstall app, reset, update,..etc and NOTHING.
It's going back to Kohls where I purchased it this weekend.
Fitbit appear that it does not care about these issues people are having. This is my third Fitbit and this will be my last.
12-18-2019 15:11
12-18-2019 15:11
How was this the best answer when it did not address the issue? I have the same problem and I will be returning mine back to Kohls.
12-20-2019 02:26
12-20-2019 02:26
The issue is in fact not answered here. I'm experiencing the same sync problems with a Google Pixel 4.
12-20-2019 05:30
12-20-2019 05:30
12-20-2019 06:16
12-20-2019 06:16
This is only a workaround, not a fix...
I've found for me when my versa2 stops synching, that shutting down the watch and restarting it will restore synching. Killing and relaunching the Fitbit app, Bluetooth, or even restarting my phone doesn't help.
You can access Shutdown on the versa2 through Settings, then About.
12-20-2019 07:13
12-20-2019 07:13
Why do you want to do all the work around when you can just purchase one of the other smart watches that I will be doing this weekend? This is a PITA watch.
12-26-2019 00:26
12-26-2019 00:26
I bought mine today. Took AGES to connect to Spotify. Then disconnected, dropped out and then comes up with "free account" when I go back to Spotify settings.. Just can't reconnect. So frustrating. I have a Samsung S10, so is compatible.
12-26-2019 07:27
12-26-2019 07:27
I am no longer a fitbit owner. I purchased some knockoff smartwatch on Amazon for $20 for the time being that is actually working. The interface is not as slick and the display options are few but this will do until i research another smartwatch.
12-28-2019 11:01
12-28-2019 11:01
SPENT HOURS fighting with my Brand New Fitbit Versa 2. Got it yesterday. Multiple reboots of all electronics (Phone, PC, Fitbit, Home Wireless network). Even Ran a factory reset on the Fitbit. Nothing would fix the instant Wifi dropping. Reviewed a lot of the pages for this. Nothing helpful.....
Remembered My wifi runs on both 2.4G and 5G.
Disabled Home network 5G Issue resolved.
Might be something @Fitbit Could look into.
Hope this helps some others.
SJLoughery.
12-28-2019 19:27
12-28-2019 19:27
6 comments?
Dude...lighten up.
Mine works great!
12-28-2019 20:42
12-28-2019 20:42
12-30-2019 09:38
12-30-2019 09:38
Hi, I have the same problem. Did some searching and found out that it is a known issue. I contacted Fitbit via live Chat line to ask that this issue be fixed. We all need to contact Fitbit and voice this issue so that complaints start to mount up and Fitbit will be pushed to action sooner. Posting issues here helps to reassure ourselves that we are not alone. The next step is to actually report it to Fitbit in numbers so that someone in their company decides it's worthy of immediate action. I don't know if previous version has this problem with Spotify. If it did,and now it's version 2 with same issue,then someone is asleep! In the meantime, the solution is to log out of Spotify free and log back into Spotify premium everytime this happens. Thank-you so much fibit for this hourly inconvenience.
01-01-2020 07:53 - edited 01-01-2020 07:59
You need to go to the Versa settings and click on WiFi setup then, once it is listed, click on connect. You have to leave the window open in order for it to stay connected. Lame, but it’s been working for me.
01-01-2020 09:04
01-01-2020 09:04
01-01-2020 09:11
01-01-2020 09:11
