Accepted call notification stays on screen
Hi I’m having problems with my Fitbit Versa when I have a missed call it’s comes up on my screen and goes away as it should but when I answer a call it stays on my screen even after the call the call has ended and doesn’t go away until I press the red button on my Fitbit I have turned my call notification off and on again any help would be great thanks
10 REPLIES 10
Welcome to the Forums @Beckyj83! Thanks for sharing your experience with your Fitbit app and for the troubleshoot you  performed before posting here. This sounds odd and it's not the expected Versa behavior.
To make sure that your watch is working correctly, please restart it. Also, set it up as a replacement device to make sure that your Versa's connection with your app is functioning as expected.
I hope this helps, keep me posted! Smiley Wink
Lucy | Community Moderator, Fitbit
Did you like my answer? Vote for it!
I have tried restarting it and deleting it off the app and adding it again as a new Fitbit sometimes it goes off but mainly as a missed call it stays on my Fitbit as a call and won’t go off until I cancel the call on my Fitbit 😞 can’t find a solution at the moment
Thanks for your reply @Beckyj83! I appreciate all the time and effort you have invested to solve this. To further assist you, I've created a Support case on your behalf.
You should receive an email from Customer Support at the email you used to register with the Community forums.
Keep me posted if you have any other question.
Good morning.
I am having the same problem on my Versa. Tried to do the same as restarting and adding it again, and remains the same.
Hope that Fitbit can fix this problem.
regards,
Luiz
Hi All,
Same here.  Call still shows on versa after I answer.  Same happens on the wife's Versa as well.  Any update on if there is anything they are doing to resolve this?
I have the same problem. Please post if anyone gets a real answer.
Same issue. Please fix! My Versa seems way more buggy than my Blaze ever was.
Hello I have the same problem with my new Versa, please help with a solution.
Piling on: Had the same issue with my Versa since May 2018.  Back button dismisses it, but stale non-functioning buttons is not a good look for my Versa.
For me it doesn:t work if I push the back button, when I check again the notification status it is still there. It happens only for missed calls, If I accept or reject a call when I clear all they disappear, except for missed calls.
